I am designing now a radio for my kitchen. It will be a simple digital radio using TAE5767 chip module.
As I know totally nothing about Audio and this is the first approach I want to use some KIT for a audio amp.
I found in Poland a 2x5W KIT based in TDA7496, but I am not sure if it is any good and the TDA7496 is unavailable. The TDA8496 looks exactly the same from spec.
Do you know any company that sells cheap audio kits like this, I would like to have more options.
Important is:
- Volume control (can be digital or voltage)
- MUTE
- Would appreciate StandBy
Also I plan to put it in wooden case so the temperature cannot be so big. But if will be a problem I will not install the back.
