I want to take a 0-10V signal and feed it into a 0-3.3V ADC, are there any general rules to using a voltage divider into an ADC.
I usually stick with values in the kohms range to limit current draw, should I go higher/lower - are there any specs to look up in the micro's datasheet to design against?
How do I go about designing the divider if I know it's xbits and y-zV range so I get sensible bits/voltage scaling in the software?
