Not only helps hold the IC die in the IC package, but it also helps remove heat from the IC die.
Without, only the super thin IC bond wires would carry away the heat from the die to the pins and the tiny IC in an all plastic package would bake itself in the center. At least with the thin flat plate of metal where the silicon sits upon, those wings to the left and right distribute the heat along the plastic case.
