Ive got here a modification pc power supply that Im using as a bench power supply, I am having a problem with the adjustable output,
I have tried a 10k pot and its only the last few degrees that adjust the voltage, because its using a small area its difficult to get it to the precise volts I need, I thought I would try a 50k pot, thinking more range more control but that does the same, whats the best solution for this please?
Thanks
