Author Topic: VFD Board  (Read 3090 times)
Offline LanceTopic starter
  • Resistance if futile if R<1Ohm
VFD Board
« on: July 31, 2012, 07:06:02 am »
I recently found a VFD mounted on a board sitting around. I managed to identify it as an NEC FIP display, and that it uses a National Semiconductor MA1003 as the driver. The board itself is marked as a National product. Thus far I've been unsuccessful in finding a datasheet on the device. It doesn't really help that the device is potted over as well. There are clearly the 6 connecters on one side of the board, one of which is unused. Beyond that I haven't been able to figure out anything else about the board.
Does anyone have a datasheet for this driver? If not I might as well go about removing the VFD from the board and trying to drive it manually.
#include "main.h"
//#include <killallhumans.h>
Offline PA0PBZ
Re: VFD Board
« Reply #1 on: July 31, 2012, 08:47:38 am »
Well, it says MA-1003  8)
Re: VFD Board
« Reply #2 on: July 31, 2012, 06:55:18 pm »
That looks like the same module. I'm wondering what the various input voltages are for the park or signal lines are. At the least I need the ignition pin set active to enable the display.
#include "main.h"
Re: VFD Board
« Reply #3 on: August 02, 2012, 09:19:20 pm »
I tested it, and it works! The trim pot on the back has been soldered into one position, I'll see if I can clean that up. In the mean time, I'll just go about putting it in a housing.
#include "main.h"
