Loading [MathJax]/extensions/Safe.js
Author Topic: Very Confusing Circuit.  (Read 10025 times)
Offline kvrestoTopic starter
« on: February 17, 2015, 08:26:28 am »
Hi Everyone.
I came across this circuit today which has me asking some questions, and I hope someone can shed some light on the subject. Its been a long day and maybe I’m confused.
From the cct pictured in the image, 24V is applied to R1, and 5V to the cathode of D2. Also R1 and R2 form a voltage divider and by my reckoning the point at VF3 should be:          12V – 5.0 – 0.7V(Vf of D2) = 6.3V
1)   So I’m wondering if my calculations are correct? And why the difference at VF3?
2)   Why is VF2 = 5.19V
3)     Also why would anyone design such a circuit, and as this is actually implemented on a functioning board, when is it ever acceptable to pump about 6V into the 5V
rail?  These are DC conditions always applied to the cct.
Thanks
kvresto.
Offline JohnnyBerg
Re: Very Confusing Circuit.
« Reply #1 on: February 17, 2015, 08:35:18 am »
It is a basic clamping circuit. As soon as the voltage across R2 rises above 5,7 V the diode starts conducting. This prevents the volage to rise any further, because of the charasteristic of the diode.
Offline SteveyG
  • Soldering Equipment Guru
« Reply #2 on: February 17, 2015, 09:01:36 am »
And VF2 is approximately one diode drop lower than the voltage at VF3.
YouTube Channel: https://www.youtube.com/user/sdgelectronics/
Use code: “SDG5” to get 5% off JBC Equipment at Kaisertech
Offline JohnnyBerg
« Reply #3 on: February 17, 2015, 09:06:01 am »
If there was current flowing through D1, one could even say that VF4 = VF2  ;D
« Reply #4 on: February 17, 2015, 10:02:55 am »
Thanks everyone.
What about current flowing into the 5V rail through the conducting diode(D2), doesn’t that upset the 5V regulation in any way, ie: perhaps overheat the regulator?
BTW the resistors R1 & R2 are 10k not 1k, the current delivered by the 24V supply is:
(24V – 5.65V(VF5) ) / 10k = 1.84mA?, Sooo I think 1.84mA – (VF3/R2) = current traveling into the 5V rail ignoring the piddlyamps into the buffer?
what does that sound like?
Yes I know VF5 = VF3 :)
Kv
Offline JohnnyBerg
« Reply #5 on: February 17, 2015, 10:13:33 am »
If there are enough consumers on the 5V rail, that is not a problem. The current that "tries" to lift the 5V rail is consumed first. To say it simply  ;)
A well know "trick" is to put a zener diode with a slightly higher voltage then 5V (5V6) over the rail, so when the rail gets lifted, it cannot be lifted over the zener diode.
« Reply #6 on: February 18, 2015, 11:26:25 am »
Thanks for the info JohnnyBerg.
I have a problem with this cct, I cant believe that the designer would accept the risk of the 5V rail lifting is ok.
This is a "Digital" board so perhaps its not so critical, but if there was sensitive analog cct's being powered of the 5V rail, I think this arrangement would not be acceptable. From memory the input to the buffer is the output of a 24V hall proximity sensor(24V=off, 0V=on/active),.... so weird?
cheers
kv
Offline JohnnyBerg
« Reply #7 on: February 18, 2015, 11:34:28 am »
Not at all. Current through R1 can be a maximum (estimate) of 24-5 / 1K = 19 mA. Current through R2 will be 5 / 1K = 5 mA.
So, current left to lift the rail = 19 - 5 = 14 mA. That kind of current is likely to be consumed by the rest of the electronics. A power on led will do the trick. Or the designer was realy smart, and put a zener on the 5V rail  8)
Offline Howardlong
« Reply #8 on: February 18, 2015, 11:40:48 am »
Meanwhile, I hope that R1 is sufficiently well rated, 1/2W at least.
« Reply #9 on: February 18, 2015, 12:13:31 pm »
I see what you mean, you've cleared up the cct operation for me, must go off and look for a zener next time I pick this board up.
cheers
kv
