Hi!
Just a quickie one!
Can anyone point me in the direction of a good logic reference book that explains the use of diodes with a 4013 D–Type Flip–Flop please?
I have an old Intracept Electronics N7118 Colour TV Pattern Generator which has one–half of a '4013 clocked by a 4.43361875 MHz CMOS oscillator, the Q output goes to pin 2 (enable) of a '4520 decade counter (pin 1 (CLK) is earthed – I understand the '4520 will count on the positive transitions of the "enable" pin when connected this way) – what is puzzling me is that there is a diode connected between "Q" (pin 1) of the '4013 and "Reset" on pin 4, with the anode connected to pin 4 and the cathode to the "Q" output pin 1.
Part of the reason why it doesn't make sense is because the diode anode is connected to "reset" pin 4 and cathode to the '4013 "Q" output pin 1, when I would expect the diode to be the other way round, with anode to pin 1 and cathode to "reset" pin 4!
I don't have the maker's original schematic for this four decades–old piece of gear by the way – I'm having to draw it out myself!
(This piece of gear was originally supplied in d.i.y. kit form to build yourself and nobody has the original plans, and I am given to understand from a Vintage Radio Forum Member that no circuit description was provided!)
Chris Williams
