I had a quick look at the schematic and marked up where the +12V and 0V, or ++V and-6V, should go. I then noticed it says link to B or C. the question is which? It will also short circuit a 470R resistor, if connected to C, which I've also highlighted, so perhaps that resistor can be removed?
