Put a bootstrapped buffer in front of it?
Phil Hobbs did this for a microchip probe jig, and posted and discussed the circuit. The basic skeleton is this: Probe --> JFET follower (CCS loaded) --> BJT follower --> (output) --> positive voltage offset (zener) --> BJT follower --> JFET drain. The CCS-loaded JFET has DC gain very close to 1, the BJT has a low output impedance and fairly high gain (0.99ish), and the follower in the drain circuit bootstraps out Cgd.
Actually I think he used a PHEMT or something, not a JFET, but you might not need that. BF862 is the usual favorite, though it's EOL now; there's an On Semi replacement out there.
Also place the output node under/around the probe node, to bootstrap the capacitance to space.
He ended up with a fairly small fractional pF input capacitance, which easily met the application requirement.
