Hello everyone,
Sorry I've been a bit quiet, it's been a super busy few weeks for me. I'm already planning to sell some to HT230 to @IconicPCB (can you do the @ thing here?), but I still need to give him a call (sorry!)
jeremy: the data sheet that comes with the HT230 in your picture shows a BP range of 222-237 C (10-90%). That seems to be quite close to a previous poster's figures for LS230:
Is there an error somewhere?
Edited: I see that the first figures are for the specific batch you received. So it looks like your batch is within the same range as the worst-case spec for LS230, implying it may work perfectly fine in machines designed for LS230.
Yep, the company I bought it from (TMC industries) sells it to people for use in reflow ovens.
Chris: Thanks very much for your input. Could you possibly get us some rough measurements of the inside of the cavity? Maybe even a picture or two
![Smiley :)](https://www.eevblog.com/forum/Smileys/default/smiley.gif)
It's interesting that it has a seal on top, I was planning on doing this too with some RTV silicone gasket and a sheet of borosilicate glass. How is the lifting of the board done? Is it using chains, or is it done with a leadscrew? And finally, what sort of guides are on the board carrier; are they just metal drawer slides or something like that?
Some updates on my end:
-> The metal shop is currently fabricating my stainless container. It's 1.2mm stainless, so I think warping might be a little bit of a problem. But for revision 1, I think it will be fine.
-> I purchased a 2kW induction cooktop, which won't detect my 1/4" stainless ball bearings as a saucepan and so turns itself off. I have 400 of them and they are definitely induction compatible, so I'm trying to decide between modifying the stove, or just getting a thin sheet of steel to activate it. I'll probably go for the sheet.
-> I've got some 0.5mm pitch BGAs (with PCBs) to solder. Should be a good challenge
![Roll Eyes ::)](https://www.eevblog.com/forum/Smileys/default/rolleyes.gif)
