Awesome stuff here and great work reversing the van bus.
I have a classic car, where I fitted Citroen C2 electric steering rack. To control that rack, it uses an ECU. Luckily, I found out that this ECU is also used in this training platform that Exxotest sells :
https://exxotest.com/wp-content/uploads/2018/03/GU_MT-DAE_EN.pdf this was very good resource to check the pins of ecu.
That document mentions CAN bus, but when looking the signals coming out from those with oscilloscope, it's lower voltage than can bus, and hooking up can-bus monitor does not register any messages. So it must be VAN bus.
That power steering ECU requires RPM and speed messages from bus to function properly. If I could send those signals to ecu, I would have a working electric power steering.
Found out in this thread that speed & rpm are sent in one message, like this 824818F8000000004428BA
Looking at @morcibacsi:s work with the library, I ordered Arduino ESP32 and SN65HVD230 can module. But just after purchasing, I read the note in github that "does not contain any bus arbitratrion logic. So I don't recommend to use it in a car.". Not sure what that means and what would it require to write that logic. This ECU is the only VAN device in that network, so probably there is not much traffic going on there.. Maybe it could work just by plain sending that message on repeat (with actual speed & rpm of course).
What do you think guys? Would that work?
