V1 provides a 5V pulse simulating a logic signal. 100V is the maximum voltage you are ever likely to need. Some VFDs can work with anode to cathode (filament) voltage differences (Va-k) much lower than that, as low as 30V for some types of multiplexed display. However the off-state grids and anodes need to be pulled far enough negative with respect to the cathode to ensure they are fully cut-off even at the negative going peak of the filament drive waveform. This means the mean cathode voltage probably needs to be somewhere around +7V to +12V, which adds to the +HT voltage required. Somewhere in the 40V to 50V range for HT is common for planar VFDs. Russian tubular VFDs generally run at higher voltages for pulsed (multiplexed) operation - up to 80V Va-k in some cases, hence the design requirement for a 100V capable driver.
You *REALLY* don't want to over-drive the anodes or grids as excess Va-k or Vg-k can cause sputtering and rapid degradation of the phosphor, the high emissivity filament surface treatment and even darkening of the glass window. Long term under-driving is also bad - it causes cathode poisoning and loss of emission. Over-running the filament obviously shortens its life and Noritake specifically caution against under-running the filament as a method of brightness control.
Must read: Noritake's
A Guide to Fundamental VFD OperationEstablishing the correct filament voltage without a datasheet can be difficult - as a rough rule of thumb you shouldn't be able to see it glow in a darkened room. It would be easier if enthusiasts with VFDs they have datasheets for or OEM displays in equipment in good working order would measure the cold resistance of their VFD filaments, and post that with either the typical filament voltage and current from the datasheet or measured in original application circuit with a true RMS meter that can handle the frequency of the filament drive, so we can calculate the ratio of cold and hot resistances as this should be more or less constant for all tugsten filaments running at the same temperature.
I haven't yet found datasheets for the VFDs I've got on hand, but the cold filament resistances and physical description are as follows:
Make, Model, Dimensions (ex. pins and 'pip'), Digit/Char height, Cold Resistance
Description
NEC, FIP13C8C, 112mm x 26mm x 8mm, 8mm 20 ohms
'Bathtub' cover glass and flat glass back with visible interior metallisation traceable to the filament and each segment and grid.
12 digits + M, minus and left arrow at leftmost position, 10 digit anodes (7 segments, dot/comma on right and apostrophe on left of each digit. The M - and left arrow have separate anodes.), 3 parallel filaments, 28 pins bonded to one edge of the back glass, 0.1" pitch arranged in two groups of 14 with a 5 pin gap centered on the evacuation 'pip' as follows in one line from left end:
1 2 3 4 5 6 7 8 9 10 11 12 13 14
F Am A- A' A< Gs Af Ag Ae G1 G2 G3 G4 G5
5 pin gap (pip)
15 16 17 18 19 20 21 22 23 24 25 26 27 28
G6 G7 G8 G9 G10 G11 G12 A, Ad A. Ac Ab Aa F
All Aa-Af anodes according to usual seven segment notation.
Futaba, 16-SD-01G, 97mm x 20mm x 6mm, 5mm, 56 ohms
Planar with visible multilayer metallisation not traceable to pins. Pins fused through frit seal. pip on end side, bottom right
16 char 5x7 dot matrix, presumably 35 dot anodes. 16 grids, 2 parallel filaments, 64 pins, 31 along top edge and 33 along bottom edge. Filament is end pins of 33 pin edge. Grids also appear to be on this edge.
