This was my first try to make a 15 stage ionizer and I had the brilliant
idea to use my UT61E to debug it. A probe on the wrong component
and after a tiny flash the UT61E was zapped to oblivion...
I don't care
about the meter itself as much as the work I've done for all the upgrades
it has. So any help would be much appreciated!
The Killer :
The "new" selection modes after the zapping :
I've tried to see if there was anything obvious on the board but there is not.
If you look at the photo below diodes
D5 & D6 measure dead short in either direction
and the double diode
D4 has a voltage drop of 0.1V in either direction as well.
(meter was in off position).
Is this normal? Looks like that these diodes are dead. What do you think?
The meter works correctly only in capacitance and Amperes mode.
I hope there was no damage on the main chip ES51922.
Can you please help me track down the problem?
Thank you!
Schematic :
