Author Topic: uSupply Custom LCD  (Read 59541 times)
Offline ataradov
    • Personal site
Re: uSupply Custom LCD
« Reply #125 on: October 24, 2017, 05:30:35 pm »
My ideal uSupply would allow me to charge my Li Ion cells.... and on completion it would show me how many mAhr it had pumped in to them.
Why would you want to charge batteries from a portable battery-based device? Seems like a huge waste. What you want is a good battery charger.
Alex
Offline mikeselectricstuff
    • Mike's Electric Stuff
« Reply #126 on: October 24, 2017, 05:37:15 pm »
I think it would be worth putting an H after the W and A , for possible other uses like a dummy load, though would also be occasionally handy on a PSU for estimating battery life
Day Job: Mostly LEDs
The following users thanked this post: NivagSwerdna
Offline NivagSwerdna
« Reply #127 on: October 24, 2017, 05:48:03 pm »
You need more imagination.  The display could be used for a variety of purposes...  and thanks Mike... "Hh" works
« Last Edit: October 25, 2017, 10:18:55 am by NivagSwerdna »
Offline ataradov
    • Personal site
« Reply #128 on: October 24, 2017, 05:49:43 pm »
That's a recipe for a project that never ends.
Alex
Offline MT
  • Country: aq
« Reply #129 on: October 24, 2017, 06:37:51 pm »
Custom LCD proposal for the new µSupply
Comments foolishly invited
And the mm dimensions are?
Offline asmi
« Reply #130 on: October 24, 2017, 08:53:48 pm »
Personally I'd prefer full LCD display if only to make the device more customizable via firmware changes.
Offline ebclr
« Reply #131 on: October 24, 2017, 09:38:04 pm »
Why not an easy programmable color serial LCD ( HMI ) like this one,  cost is approx 5 USD, no tooling no nothing, and design can be changed at any time the software guy wants
Offline Mr. Scram
  • Display aficionado
« Reply #132 on: October 24, 2017, 09:45:51 pm »
That's a $15 screen by the time it reaches the customer. The quality seems unknown.
Offline Whales
    • Halestrom
« Reply #133 on: October 24, 2017, 10:33:46 pm »
Be very wary of that product shot.  The screen's picture looks absolutely perfect, with pure blacks and perfect whites, even better than the contrast of the rest of the photo.
Offline ataradov
    • Personal site
« Reply #134 on: October 24, 2017, 10:36:01 pm »
The picture is obviously photoshopped, I thought it was obvious to everyone.
Alex
Offline julianhigginson
« Reply #135 on: October 25, 2017, 12:44:26 am »
because there's about 3 pages discussing that in the thread already and dave has explained why not multiple times?
Online EEVblogTopic starter
« Reply #136 on: October 25, 2017, 12:57:31 am »
Latest version:
« Last Edit: October 25, 2017, 01:02:39 am by EEVblog »
Offline ataradov
    • Personal site
« Reply #137 on: October 25, 2017, 01:00:55 am »
Latest version:
Looks great, IMO. What are the dimenstions?
Alex
Offline Dubbie
« Reply #138 on: October 25, 2017, 01:01:01 am »
Nice Dave.
Can you fix the kerning on the mJ and Wh. It will help legibility and look more polished.
Offline Mr. Scram
« Reply #139 on: October 25, 2017, 01:07:30 am »
That already looks a lot more mature than the previous version. I like the increased legibility of the things in solid blocks.
I do notice that the MIN/MAX aren't sized the same on the volt side of things. That should of course be a minor fix.
Offline asmi
« Reply #140 on: October 25, 2017, 01:21:05 am »
Latest version:
Not sure if it's possible, but it would be awesome if volts and amps would have different colors. Never underestimate the value of a quick glance!  :-DMM
Offline Mr. Scram
« Reply #141 on: October 25, 2017, 01:23:22 am »
Considering those colors seem to be different on different equipment, I think you need a second look anyway. After a handful of uses, you should know whether the upper indicator is volts or amps.
Offline jaycee
« Reply #142 on: October 25, 2017, 02:48:21 am »
Latest layout looks great, and has a multitude of uses. Maybe you'd even consider selling them individually for those of us brewing our own PSU's too ? :)
Offline Seppy
  • Curious
« Reply #143 on: October 25, 2017, 03:30:50 am »
Nice Dave.
I didn't even notice the kerning problem, it happened in the conversion from vector artwork to png. Weird.
Yeah that was fixed, forgot to update the section with the MIN/MAX template.
Thanks everyone!
Online mariush
« Reply #144 on: October 25, 2017, 04:06:27 am »
Not sure I dig the single "inverted" icon on the right, the ON text... it's like it makes everything off balance.  I like things vertically aligned and symmetric.
Wonder if it wouldn't look better on the left in the same shape as the CV and CC icons and then have that whole row moved to the right and have 0 instead of 1 (should fit, since the ON would be slightly smaller) .. why have just "1" there when everything else is full 7 segment
Speaking of which, wouldn't the controller they put on the back of the lcd display have some limitation about the number of segments and all that? Are there price jumps depending on the segment count ?
Looks like around 160 segments to me (just multiplying the digits by 7 segments, adding dots and all that)...
Offline Seppy
  • Curious
« Reply #145 on: October 25, 2017, 04:37:04 am »
We thought ON was perhaps the most important display icon, this is why it stands out the most and on its own.
« Last Edit: October 25, 2017, 05:01:50 am by Seppy »
Offline VEGETA
  • Country: jo
  • I am the cult of personality
    • Thundertronics
« Reply #146 on: October 25, 2017, 05:16:12 am »
If it is custom, how can you drive it via MCU? I mean, will it be the same like other LCDs?
Offline ataradov
    • Personal site
« Reply #147 on: October 25, 2017, 05:19:46 am »
LCD controller chip. This was already mentioned in this thread.
Alex
« Reply #148 on: October 25, 2017, 05:49:09 am »
This is not a COG display, controller is external for cost reasons.
The external controller supports 8 COM x 32
Offline JPortici
« Reply #149 on: October 25, 2017, 06:06:37 am »
Or there could be a separate microcontroller for the user interface which also has a segment LCD controller builtin (maybe not in this case but it is another alternative)
