Author Topic: Using jumpers to quickly swap components  (Read 4520 times)
Offline HendriXMLTopic starter
    • KiCad-BOM-reporter
« on: February 20, 2019, 01:50:15 pm »
Did a quick experiment on how to use jumpers to make resistors (or other components) swappable, to enhance the joy and speed of experimenting on a perfboard.
It needs a bit more spacing because of the 2x2 headers.
But compared against using crimped/soldered dupont connectors they are handier.
  • Using the test perfboard you get a "third hand"
  • No need to crimp
  • Good orientation
  • Spacing is accurate
  • Easy to have different spacings
  • Easy to swap
  • Shorter “legs”
  • More isolated
I measured the voltage drop of (2) it was 17.9 mV at 3.2A making a resistance of 5.6 mOhm.
The used wire in between dropped 0.9mV so it had a resistance of 0.3 mOhm.
Thus the jumper connections are about 5.3 mOhm.
Good enough for a lot of applications!
While soldering some care has to be taken not to solder to the header.
« Last Edit: February 20, 2019, 08:07:06 pm by HendriXML »
“I ‘d like to reincarnate as a dung beetle, ‘cause there’s nothing wrong with a shitty life, real misery comes from high expectations”
Online magic
Re: Using jumpers to quickly swap components
« Reply #1 on: February 20, 2019, 02:27:10 pm »
Pro tip: check out SIL/SIP sockets.
« Reply #2 on: February 20, 2019, 02:34:12 pm »
They’re on order. Had previously only bought one strip. That one I used as a tiny breadboard  ^-^. Handy stuff.
Maybe I will do a comparision, but I don’t think the tick wire will fit  :-+
« Last Edit: February 20, 2019, 02:36:51 pm by HendriXML »
Offline Ian.M
« Reply #3 on: February 20, 2019, 02:43:13 pm »
You can also cut up turned pin IC sockets if you don't have any SIL turned pin socket strips handy.   For components with a similar lead diameter to the turned pin pin, if the lead is cut cleanly it will plug straight in.  If there is a moderate diameter mismatch, solder the lead into the socket side of another turned pin socket and use the pin side as a plug.
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #4 on: February 20, 2019, 07:33:46 pm »
IC sockets may be a bit too tight, in which case the next best (top best??) option would be Mill-Max headers/sockets, available in all sorts of sizes.  Pricey as frig though.
Plain rectangular spring contacts would be fine (how solderless breadboards do it), but they don't seem to be as available, with contacts sprung for small minimum diameter leads.  Regular 0.025" square pin header sockets are pretty wide open, not good for much besides square pins.
I've done it that way too, with a socket header in the board and components soldered to pin headers.  Not as freely pluggable as random proto-bin components (need to prepare a component+header assembly), but alright when you have just a few combinations to try.
Seven Transistor Labs, LLC
Offline NorthGuy
« Reply #5 on: February 20, 2019, 07:43:50 pm »
Looks like you're re-inventing solderless breadboards :)
« Reply #6 on: February 20, 2019, 07:50:12 pm »
But with the benifits of inhaling solder fumes  :-+
Offline Audioguru
« Reply #7 on: February 20, 2019, 08:49:46 pm »
Wait a minute! Why do you need to swap components?
Because you never learned how to simply calculate their values and you are using "trial and error" instead?
I never guess about component values, I calculate the values by reading the datasheet minimum and maximum spec's for an active device the components are used with. Then my circuits work perfectly without changing anything.
Oh yeah. I buy quality parts, not junk from "over there".
« Reply #8 on: February 20, 2019, 08:58:59 pm »
That’s cool. The way I “calculate” my fuses for instance is that I start with the lowest value one and then climbing up until the new one doesn’t blow any more.  :-DD
Offline Audioguru
« Reply #9 on: February 20, 2019, 09:19:44 pm »
I hope you don't do the same with car tires and other car parts.
« Reply #10 on: February 20, 2019, 09:31:56 pm »
Lots of calculations, but gladly also a lot of testing is done when designing car tires. It’s hard to fully model the real world, you must agree on that. Experimenting and checking is as a method simply irreplaceable.
« Last Edit: February 20, 2019, 10:37:24 pm by HendriXML »
Offline james_s
« Reply #11 on: February 20, 2019, 09:58:51 pm »
I calculate to get a reasonable starting point but I often find that I need to tweak things a little in the real world to get some things working properly. Other times I'll be doing more of a seat of the pants thing and just experiment to see the effect of a particular component on the circuit. Being a very visual thinker I find that a lot more interesting than plugging numbers into an equation. Not everybody playing with electronics is a professional engineer and there's no reason to look down on them for that. You have a process that works for you, he has a process that works for him, so what?
I mean did you come here to help, or just to show off how smart you are?
The following users thanked this post: Heartbreaker
Offline KL27x
« Reply #12 on: February 21, 2019, 12:37:50 am »
I spent a couple years making "useful stuff" like this. I think it's just a phase some of us go through. :) Prediction. In 2 years, you will be using mostly smd parts and swapping them out with a hot air station.
« Reply #13 on: February 21, 2019, 12:52:26 am »
Just curious, but how does one prototype with smd parts without using designed pcb’s?
Offline Fire Doger
  • Stefanos
« Reply #14 on: February 21, 2019, 01:27:09 am »
They don't, they design PCBs *(Unless you mean prototyping something basic that can be calculated on the back of an envelope)
The question is what kind of pcbs
For simple layouts
They break it into small schematics according to functionality and build them individually for faster workflow, debugging etc...
If its simple (no tiny tracks, BGA etc) then probably you can do it on a diy pcb. If you got a set up for home pcds it will be very fast.
It takes me 1h to print it while doing something else at the same time.
For complex layouts (BGA - Multylayer)
You rely on datasheet, examples, appnotes, etc. Good EDA helps too.
Many times "calculating" may be much more expensive than building it.
Everyone at the end have to build it as final product. PCB is part of the circuit and interacts with it. (you can see it clearly when speed-voltage-current-temperature goes up)
Ending with many prototype pcbs is not unusual... The key is to minimise the number/cost of them.
« Last Edit: February 21, 2019, 01:30:57 am by Fire Doger »
« Reply #15 on: February 21, 2019, 02:15:37 am »
For simple layouts
Thanks. Making my own PCB’s is not on my list yet, and to have them manufactured takes a while. So in the mean time I’ll be having fun with THT and perfboards. For me it is a hobby, where I find the part of soldering fun as well. Desoldering not so much, hence the topic.
Offline james_s
« Reply #16 on: February 21, 2019, 02:47:44 am »
I've been prototyping lately on blank copperclad, sort of like the old "deadbug" technique. I could never get past the ugly mess it looks like previously but I've managed to develop a fairly tidy technique and it sure performs well for high frequency stuff. Things like SMPS ICs and mosfet drivers that I previously had a lot of trouble getting to work correctly are no problem this way. Big continuous ground plane works even better than a regular PCB in many cases.
Offline Audioguru
« Reply #17 on: February 21, 2019, 03:31:13 am »
My help is for you to read the spec's in the datasheets then calculate what is needed to meet them. Also to buy quality components.
A model was mentioned, for a simulation? Most simulations simply use "typical" active parts, ignoring minimum and maximum spec's so some of the assembled circuits will not work. You can either throw away the ones that don't work or fiddle with them if all the spec's were ignored.
Online Siwastaja
« Reply #18 on: February 21, 2019, 09:25:50 am »
Easily.
- 0402, 0603 and 0805 passives fit between two pads on standard through-hole breadboards, if you want to use those. SOT-23 and similar also fit just fine,
- For many circuits, use bare copper clad FR4 as a full ground plane. Dead-bug ICs (turn them around), bend the ground pins and solder them down. For power decoupling, you can solder another end of a 0603 cap to the ground copper, another end to the pin directly. For the rest, solder in air wires. Fairly easy to solder a 0603 resistor directly to a pin, leave another end hanging in air, later solder a wire to this pin.
Not much slower than working with through hole parts.
« Reply #19 on: February 21, 2019, 10:38:10 am »
Easily.
With KiCad (which I use) it is possible to flip the board, thus it should stil be possible to have some visual guidance. I’m using that already to create “traces”. Using a perfboard it should also be possible to mix THT and the dead bugs. Dead bugs are then soldered on the bottom side. The “step up” to SMD for me will probably go slowly, so I like this possibility! I know that there’re also adapter boards for SMD, but those aren’t that cheap and you need to have them at stock.
« Last Edit: February 21, 2019, 10:47:57 am by HendriXML »
Offline T3sl4co1l
« Reply #20 on: February 21, 2019, 12:21:25 pm »
With a utility knife:
Note I tend to mix "Manhattan style" construction (PCB chits making elevated tie points) and THT components (which can be wired pretty much anywhere, they're free jumpers).
Offline netdudeuk
« Reply #21 on: February 21, 2019, 12:45:43 pm »
You can use the OP's proto board for SMD prototyping
http://elm-chan.org/docs/wire/wiring_e.html
Offline Buriedcode
« Reply #22 on: February 21, 2019, 03:00:40 pm »
Just wanted to add, SMD parts work nicely with stripboard too.  1206 is usually needed to span tracks broken with a drill bit (broken at a hole) but 0603 or 0805 are fine for connecting adjacent tracks.  Because SMD passives tend to be very cheap (except maybe higher value caps) I use them as often as possible.
Offline netdudeuk
« Reply #23 on: February 21, 2019, 03:27:08 pm »
The passive components in the photo that I included above are 0805s.  The holes in the board are 0.1" pitch so they fit how the same components would appear on stripboard.
« Reply #24 on: February 21, 2019, 09:34:47 pm »
Thanks for all the reactions, it really shows there’s not one “right” way to do stuff!
