Author Topic: Comparator input noise issue.  (Read 277 times)
Offline kushal4269Topic starter
  • Country: in
« on: July 28, 2024, 09:09:23 am »
I am using LM393 op-amp as zero crossing detection.
circuit uses dual supply with positive and negative supply of 5V as I have differential signals.
When I connect signal it creates square wave according to input, but due to inherent noise in input comparator output is also noisy near transition.
Is there any way I can remove or reduce input noise when no signal is connected to opamp(i.e. inherent noise of input) So I can get clear output. I am using both the op-amps of dual op-amp IC LM393 as I have two different signals.
« Last Edit: July 28, 2024, 09:11:17 am by kushal4269 »
Offline Circlotron
The following users thanked this post: ledtester, kushal4269
Online moffy
Re: Comparator input noise issue.
« Reply #2 on: July 28, 2024, 12:05:32 pm »
Further to what Circlotron has already mentioned, add some hysteresis or positive feedback to the comparator:
https://www.ti.com/lit/ug/tidu020a/tidu020a.pdf
https://circuitcellar.com/resources/comparator-hysteresis-2/
The following users thanked this post: kushal4269
