Author Topic: using an MDAC vs a regular DC at adjust voltage amplitude...  (Read 496 times)
Offline Gibson486Topic starter
« on: January 29, 2023, 01:46:00 pm »
I was looking to adjust the amplitude a 350khz sinewave signal....Digitpots seem way to frequency limited unless I pick a lower resistance version. DAC seem to be frequency limited on the verf as well, although not a badly as digipots...does this mean I have to go the MDAC route for frequencies above say 100khz? Or am I just searching digikey the wrong way and need to search deeper? I have no issue using  MDACs, just rather not have to deal with the output amp (trying to use the least number of parts possible).
Offline moffy
Re: using an MDAC vs a regular DC at adjust voltage amplitude...
« Reply #1 on: January 29, 2023, 02:37:37 pm »
You can use an MDAC, or PGA if you want digital control of the amplitude. A VGA amplifier e.g. AD8336 (one of many) gives you analog control of the amplitude, depends on what you want.
