Author Topic: Connectors for a RS485 network  (Read 885 times)
Offline darrenbTopic starter
« on: August 05, 2019, 02:35:06 am »
I have to put together a RS485 network on of all things a super maxi called InfoTrack.
The network is to connect together a PLC, an Arduino and a Raspberry Pi using Modbus.  I've got these all talking to each other now I just have to come up with the actual cabling and connectors.
As I haven't been able to google anything off the shelf for this the best I have been able to think of so far is to use a 6 terminal terminal block at each connection point and mount this in a jiffy box.
The six terminals are 1 to 6, 1 and 2 for the RS485 network coming in or if there is no other connection a 120 ohm resistor.  3 and 4 for the A and B for the device at this point (pi, arduino etc) and 5 and 6 for the RS485 network going out or another resistor.
On the other side of the terminal block I'll just wire 1 and 3 together, 2 and 4 together and so on.
For cable I am thinking of using 4 core twisted pair telephone cable.
This should all work but I can't help thinking there must be a better way.  Surely other people have had to create RS485 Modbus networks?
Online ledtester
Re: Connectors for a RS485 network
« Reply #1 on: August 05, 2019, 02:58:53 am »
I think RJ45 (i.e. ethernet) cables are commonly used for RS485. Yeah it's overkill, but then you have future expansion possibilities and you also have a cable run which can be used for lots of other purposes.
You might plan out your conductor assignments so that you can carry both RS485 and 100-baseT ethernet (which only requires 2 twisted pairs) at the same time.
« Last Edit: August 05, 2019, 03:08:56 am by ledtester »
The following users thanked this post: darrenb
« Reply #2 on: August 08, 2019, 11:15:38 pm »
I just realised that I also have to provide ground and maybe also a shield connector so my idea of using a 6 terminal terminal block won't work.
Looks like I'll have to make up a pcb using either rj45 or rj11 connectors.
Offline digsys
    • DIGSYS
« Reply #3 on: August 09, 2019, 12:08:32 am »
I've used several methods over the years - including phoenix 0.15" 6/8W pluggable >> and now using CAT6 shielded PoE pinouts, which I also use for CAN Bus.
In serious "factory" electrical connections though, I always go for fiber > fiber converters
Online vk6zgo
« Reply #4 on: August 09, 2019, 12:12:49 am »
The only RS485 network I've had anything to do with used 9pin "D" connectors.
A  bit clunky, maybe, but they have plenty of spare pins to play with!
