My interest in talking about kikusui power supplies was to see which technology was used in a linear solid state commercial HV power supply.
This does not change my point of view that, for a hobby application and home-made power supply, the vacuum tube solution is the simplest and safest.
I'd choose a switched mode power supply myself. It's not that difficult nowadays, even for hobbyists, with the vast range of controllers and high performance MOSFETs available.
Yes I fully agree with this
, but did you looked at the crap schematic that 001 has posted.
Do you really believe he is able to developp and to build a switch mode power supply ?
In first instance, we should try to answer to him with an answer he is able to use....
And who will developp this switch mode power supply for him ?
Have you time and money to do it ?
You will not only have to post the schematic but also to give him all the informations about how to build the ferrite transformer and inductors....
