I was thinking of making a desktop sculpture using those little neon indicator lamps.
The question is: How to power it?
Those things need 90V to light up but then they drop down to about 50V in use. You need to put in a current limiting resistor.
They use about 1mA of current each and I'm thinking 20-25 lamps.
The easiest way would be mains A/C (in a closed jar with fuse+isolation transformer, obviously) but I'm wondering if it could be powered via USB. With USB power I could take it down the pub to show it off, etc.
What would be a simple circuit to do that? Would a joule-thief-type circuit work with those lamps or do I need to go the full hog with a little transformer, 555 timer, rectifier, etc?
Any ideas welcomed...thanks!
PS: I'd like the circuitry to be small/hidden if possible.
