Hello
I'm a mechanical engineer but have bases of electrics and some concepts about electronics but never did any electronic project. I'm more into mechanical and basic electrical stuff (wiring for home, etc). I have soldering skills, multimeter and stuff, but never did more than replacing bad capacitors, transistors, switches, cables, etc.
Anyway, I've built a big transformer to give 1.2V AC at ~2000 Amps. At this moment i only have a powerswitch on the mains AC input and use that manually to set the time (with my wrist watch chronometer and shutting the power off when i think it's ok).
I have a big mechanical relay rated for 50Amps AC with coil voltage of 12V, and have a readymade 12V PSU (a brick type) that can operate that relay. I plan to use this insted of the switch on the mains (220V 50Hz here), that will draw some 10-14Amps with spikes over 18 at start.. this is what a clamp-meter says when i'm using it)
Now I'd like to add a timer circuit to do the following: Have a range from 0.1s to 30s that can be set with a potentiometer (or some switches for rough adjustments), a diplay would be nice but i don't know anything about them (i can calibrate that potentiometer with a chronometer and make a scale for what it does) - it's not about precision since it's eyeballing type of weld but would be nice to remember what settings worked best on certain types of sheetmetal. And a button to start that timer to close the relay to turn on the power to transformer to start the welder and keep the power going for that amount of time. Increments in 0.1seconds would be great, and tipically 10-20s would be enoung but would like to extend that to max 1-2min if within range for experimenting with thicker plates on car bodys
So from what i know i need either an arduino to do this (i'm not into programming arduino but i have base knowledge about programming in general.. will have to learn first), or some 555timer to control that relay (how do i use this to give me the range i want and to do a single count then stop until that button is pressed again?)
Never dealt with either of them.. so what would be an easy approach? like what components to use, what to buy?
