Author Topic: Low-cost USB data isolation using a transformer?  (Read 411 times)
Offline danieljfarrellTopic starter
« on: September 04, 2024, 10:42:50 pm »
Hi all,
I'm looking at using the https://www.analog.com/en/products/adum3160.html for isolating USB data, I would like full speed (12Mpbs) but actually slow speed (1.5Mbps) would probably be fine.
But I'm curious why there is not a cheap high-speed transformer approach that solves the same problem. For example, a 1:1 transformer for the D+ and another for the D-. The transformers would slew the rise and fall of the edges, let's guess a 2ns rise/fall time, the USB clock rate is 1/(24Mhz) ~ 40ns gives the duration of the data high or low. As long as the transformer does not delay the rise time longer than 1/10th of 40ns = 4ns, then I think this should work. I don't know much about high-speed transformers, but I guess this is too much of an ask, or is it?
There are a lot of transformer options for CAN, RS-232 etc, https://www.coilcraft.com/en-us/edu/series/understanding-and-selecting-isolation-transformers so why not USB?
Happy to be educated :)
Offline DavidJRobertson
  • Country: scotland
    • davidr.me
Re: Low-cost USB data isolation using a transformer?
« Reply #1 on: September 05, 2024, 12:23:57 am »
USB 1.0/1.1/2.0 (but not 3.0 onwards...) requires DC coupling on the diff pair, so a transformer alone will not work.
Online moffy
« Reply #2 on: September 05, 2024, 12:25:21 am »
From my understanding USB also uses DC levels as part of the protocol and also for power demand levels, it's moderately involved.
https://www.engineersgarage.com/signal-and-encoding-of-usb-system-part-5-6/
Offline Irilia
    • My YouTube channel
« Reply #3 on: September 05, 2024, 03:27:52 am »
This is probably your best option.
> https://a.aliexpress.com/_EQ7w56Z
« Reply #4 on: September 05, 2024, 09:04:00 am »
Thanks everyone,
I didn't realise DC coupling was in the specification for the data lines. Interestingly that is missing on USB-C so there might be some options there...
That ADUM4160 board is virtually as cheap as just buying the IC.
Thanks,
Offline exmadscientist
  • Technically A Professional
« Reply #5 on: September 05, 2024, 10:07:58 am »
Be mindful that USB-C connectors carry both the older D+/D- (aka USB1, USB1.1, USB2.0, Low Speed/LS/1.5, Full Speed/FS/12, or High Speed/HS/480) pairs and the newer SS (USB3.0 SuperSpeed/5Gbps aka ... okay, even this rant/joke has gone too far, just because it's a Universal bus didn't mean it had to get a whole Universe of silly nomenclature too) pairs.
So just because you're using Type-C connectors doesn't mean you're free of the original data signals. They're just present together in parallel.
