Author Topic: USB and battery power source  (Read 605 times)
Offline jmbinetteTopic starter
« on: September 21, 2019, 11:10:47 pm »
Hi to all,
I built a circuit to power a 3.3v power source using both battery and/or USB cable.
The battery section of my circuit seems to work fine.
the USB section is using a LP2985-33 and I cannot get 3.3v at the output.
instead, I get like 1.7v
My schematic is attached
Any suggestions?
Is my design good to avoid leakage into the battery ?
thanks
Online ledtester
Re: USB and battery power source
« Reply #1 on: September 22, 2019, 05:02:00 am »
Is GND of the LP2985-33 connected to USB GND?
The following users thanked this post: Vcky_electro
« Reply #2 on: September 22, 2019, 06:39:04 pm »
Damn right !Oops |O
Everything good now !What about the rest of circuit,is it a good design ?
Offline Vcky_electro
  • Country: in
« Reply #3 on: September 24, 2019, 06:57:47 pm »
Nice.. :clap:
Offline Kasper
« Reply #4 on: September 25, 2019, 03:21:48 pm »
Check the datasheet for max40200. Does it have reverse current blocking? What happens if Vout is 5V and Vin is 4V?  Many regulators have max Vout = Vin and if Vout > Vin, current flows the wrong direction.
Adafruit has some good example circuits of connecting battery and usb I think feather 328P has a good one.
