Author Topic: [SOLVED!] Can you download me the datasheet pls? Samsung  (Read 1857 times)
Offline YansiTopic starter
  • STM32, STM8, AVR, 8051
« on: April 26, 2016, 07:27:26 pm »
My friend has this samsung panel... but the datasheet nowhere to be found.  Samsung lt141x4-156
Until this showed up:
http://www.rcgroups.com/forums/showthread.php?t=2202605&page=54
But what the f? Although the thread is about two months old, the yesyesyes server with its idiotic name doesn't work, at least here. Can somebody please try to download it or was the server really trashed?  The only server with the PDF... Damn internet...
http://yesyesserver.co.uk/display/141x4_156-pin.pdf
Thank you very much!
Yan
« Last Edit: April 26, 2016, 08:24:48 pm by Yansi »
Offline cowana
Offline hendorog
Re: Can you download me the datasheet pls? Samsung
« Reply #2 on: April 26, 2016, 07:37:01 pm »
The server was down for me too, but you can see the datasheet (without any images) by doing this:
Enter this into google:
141x4_156-pin.pdf
Then click on the tiny down arrow next to the Green URL in the yesyesserver.co.uk result.
Select 'Cached'
That will show the copy of the pdf google has cached - which seems to at least show the pinout.
Offline kripton2035
« Reply #3 on: April 26, 2016, 08:00:58 pm »
also in the web archive :
http://web.archive.org/web/20131228145530/http://yesyesserver.co.uk/display/141x4_156-pin.pdf
but yes this is a very sparse datasheet...
« Reply #4 on: April 26, 2016, 08:24:13 pm »
Awww yea... didn't know about google providing cached files! Thanks!!
The pinout it almost enough, as other parameters I have already found scattered throughout the web.
Thank you for help!
Yan
