In LDO or SMPS circuits, the maximum capacitive load is generally specified. Is the capacitance at the output of the LDO or SMPS circuit used after the SMPS LDO output also included in the output capacitance of the main SMPS or LDO?
If there are additional capacitances downstream from the LDO or SMPS output, such as capacitors at various stages of a power distribution network, are nthey typically included in the specified maximum capacitive load of the LDO or SMPS itself?
For easier understanding, should Capacitors C2 and C3 be included in the output capacitance load of Smps1?
