Hi!
I'd like to build a transformerless power supply, but I'm not sure if I can use 250V rated standard film capacitors (x2 for example). Mains voltage in my country is 230VAC, which means 324V peak DC, so this looks like not so good idea, but since those capacitors are used directly on mains or phase to earth / neutral to earth for Y capacitors, I think there shouldn't be any problem with this, although voltage rating is only 250V. So, would that work?
Thanks
