At work we use a
IPS6044G which is a four channel intelligent protected high side switch. It also offers active clamping to demagnetise inductive loads quickly.
Now, I don't understand the following part: the datasheet states that the maximum output voltage is Vcc-35V. (In our application VCC=24V, so that equals to -11V). The specified clamping voltage is between 37 to 42V so during active clamping the voltage at Vout can be as low as 24-42 = -18V. That's 7 volts more then is allowed
In an actual test I measured -15.8V which basically confirms the clamping voltage ~39V.
What use is this active clamp circuitry if it consistently violates the absolute maximum rating? Or am I misinterpreting the specification?
I asked IRF about it; their answer is that I should use another series as this one is not meant for 24V and they referred to
appnote #1117 which is not really helpful on this particular issue.
I looked at other high side switches like from Infineon and ST and they don't mention an absolute maximum rating at all for the output, just a clamping voltage...
