As far as I know you can not run multiple types of simulations from a single 'Run'. The reason for my thinking is that LTspice would not know which data to display if you clicked on a point.
You can do the following:
You can display the operating point when doing an AC analysis:
The way to do this is:
Right click on blank are on the schematic.
A box will open select 'View'
Make sure that the box 'Show .op data flags' is checked
Left click on 'place .op data label'. Place the data label on the node that you want to observe.
Every time you run the simulation the '.op data flags' will be updated. Try changing the voltage V1 and run the model you will see the operating point update.
I have attached a zip with the model.
This also work in the time domain. I have modified the model to add a second source. Note: one of the simulation commands is now a comment.
I have also attached a zip file with this model.
Jay_Diddy_B
