Hi all,i have built variations of this in the past,see attachments,that was with an lm 723,i now have a infinion sg3532 ic to replace it with,i chose it as the cs threshold is 80mv as oposed to 600 with the 723,i plan to use 10x 2n3773 pass transistors driven by a tip 122,also have a range of 50w current sense resistors that i can switch for different ranges,i have a 50v 120.000uf filter cap and a 150amp bridge,can i use the 723 shematic attached to do this,with mods for higher power?,ie sub the 723 with the sg?,just pulling the sd pin low?,cheers in advance.
