I am trying to write atmel at28c256 on breadboard so I tied all address lines to ground, and all I/O lines also tied to ground. I untie I/O lines for reading, tie 'WE to high, 'CE to low, and 'OE to low for reading. I am reading all ones at I/O ports, no matter what address. So, when I try to write this eeprom I put 'OE high and with 'WE line I touch to ground so that should write stuff to memory but it does not, all I/O ports were connected. I also made small RC circuit with button on WE but that also does not work. Any toughts?
