Hi everyone,
as already stated in a thread in the beginners section, I will now start a thread here regarding my first bigger electronics project. This is purely a hobby project that i want to do mainly as a learning experience.
The goal of this project is to create a power over ethernet splitter capable of outputting more than 2A at 5 Volts.
This will be my first bigger electronic project, and the first where I will create a custom PCB. I want to reach at least a prototype stage in this project. If it will go any further than prototypes for personal use will have to be seen.
I want to create this thread for a couple of reasons:
- since this is my first project of this kind, i would like to get input at all stages of my project.
- hopefully, a thread like this, where a project is documented from start to (hopefully) finish can help other forum members that want to do something similar
- I also want to create a bit of peer pressure for myself, since I sometimes have massive issues motivating myself to actually do something productive with my free time
I have thougt a lot about this, but have not actually put much to paper yet. A rough outline I see for the project is about as follows:
- set requirements: already done, but additional requirements might surface
- choose the PoE chipset. Since the chipset is the heart of the project, I think it is the first component i have to look at
- determine the rest of the BoM, depending on the chosen chipset, the requirements and component availability. After this point there should be no more changes of requirements
- create schematic
- create board layout. Might result in changes of the BoM
- acquire components for a couple of prototypes
- get the PCB manufactured
- assemble and test
Each of this would be a distinct project step.
Here is my first step in this project, the actual requirements:
- compliant to PoE standards 802.3af (PoE) and 802.3at (PoE+)
- Preserving Gigabit Ethernet
- 5V output with at least 2A (802.3af would be enough for that case)
- overload protection
Optional:
- Auxilliary input to supply power if PoE is not available
- Display current PoE status
- ability to output additional/different voltages for special requirements
- Currently there is no hard size requirement. The board should not be bigger that an Arduino though
Nice to have:
- Some way to communicate with attached devices
I am open regarding some other features that would be nice to have.
The next step is step is selecting the PoE chipset. More on that in the next post.
