Author Topic: Replace masked ROM with EPROM, what to do with output enable pin.  (Read 682 times)
Offline XenonTopic starter
Currently I am repairing an old Tektronix 4051, and I suspected 1 or more ROMs to be faulty (they are MCM6832 ROMs).
The ROM images are available on the internet so I compared them to those with my EPROM programmer. From the 16 ROMs 1 appeared to be faulty. Every read action the checksum was different.
Now I am planning to replace the defective ROM with an EPROM, preferrably a 2732 since I have those in stock (a 2716 is an exact replacement). I'll have to make an adapter pcb since they are not directly pin compatible. Testing the ROMs in my programmer was done the same way.
The ROM (or the 4051) only has "chip select".
The EPROM has "chip select" and "output enable". According to the datasheet the output enable has to go low several microseconds after the chip select.
Is this critical? In other words, can I tie the chip select and output enable together so they go low at the same time? Or can I tie the output enable to ground permanently?
I can try to find this out by trial and error, but the required knowledge might already be available here on the forum. And there may be more faults in the computer so I cannot test this in a known good system.
Thanks in advance.
Online wraper
  • Country: lv
Re: Replace masked ROM with EPROM, what to do with output enable pin.
« Reply #1 on: October 03, 2021, 04:50:46 pm »
CS of that ROM effectively is the same as output enable in 2732. Tie chip enable permanently and use output enable as CS of MCM6832.
The following users thanked this post: Xenon
« Reply #2 on: October 03, 2021, 07:09:01 pm »
Then I interpreted the following text on the datasheet the wrong way.
I'll just start with E to ground. When that doesn't work I'll try it the other way around.
The  M2732A  has  two  control  functions,  both  of
which must be logically satisfied in order to obtain
data at the outputs. Chip Enable (E) is the power
control  and  should  be  used  for  device  selection.
Output Enable (G) is the output control and should
be  used  to  gate  data  to  the  output  pins,  inde-
pendent of device selection.
Offline Benta
« Reply #3 on: October 03, 2021, 07:32:14 pm »
Totally wrong! The /GVpp pin is unimportant and should just be tied low.
The /E pin must be connected to the /CE line. Period.
Online wraper
  • Country: lv
« Reply #4 on: October 03, 2021, 08:01:51 pm »
It will make time to valid output being twice as slow (you will save some power though), and if you use the slowest grade of 2732 it may become slower than the max delay spec of MCM6832. As you can see, CS actually is just an output enable.
« Last Edit: October 03, 2021, 08:26:15 pm by wraper »
« Reply #5 on: October 03, 2021, 09:20:16 pm »
Many opinions  ;D
After posting my question I found this in another 2732 datasheet:
To most efficiently use these two control lines, it is
recommended that E be decoded and used as the
primary device selecting function, while G should
be made a common connection to all devices in the
array and connected to the READ line from the
system control bus.
This ensures that all deselected memory devices
are in their low power standby mode and that the
output pins are only active when data is required
from a particular memory device.
I should have found this earlier, but the discussion is interesting. I'll try out both ways and post my findings here.
Know what, I'll also try it with both lines connected to CE.
I'm curious.
After all it says "to use the control lines most efficiently" and not "to use the control lines correctly". This suggests to me there is more then one way to use them.
« Last Edit: October 03, 2021, 09:23:37 pm by Xenon »
Online wraper
  • Country: lv
« Reply #6 on: October 04, 2021, 07:53:23 am »
I'm curious.
It will work the same as the variant suggested by Benta. /G input does not matter when the chip is deselected, and when selected it will be always active anyway.
Offline gcewing
« Reply #7 on: October 04, 2021, 02:05:12 pm »
I can't see anything in the datasheet that requires any particular timing relationship between Chip Enable and Output Enable.
