Historically, 'E' side* cables were lead, with paper-wrapped copper conductors inside. They were fed with air from the exchange, under modest pressure, to keep water out if the lead should be breached. Each cable had an air flow meter and every month I had the job of reading and reporting the readings. The idea was that an increase in air flow would signal a breach and trigger an investigation before the breach got big enough to flood the cable.
It was beneficial if the manholes or joint boxes were flooded, because all that was required was to look for a stream of bubbles. Otherwise, fault location took longer.
*'E'-side cables are those going from the exchange to the cabinets (PCPs - primary connection points). 'D'-side cables go from the cabinets to the pillars (SCCPs - secondary cross-connection points) and DPs (distribution points, which are terminal blocks at the top of a pole or a joint in the pavement).
From the 1960s, and possibly earlier, the 'D'-side cables were polyethylene-insulated and grease-filled (actually vaseline, I believe) to prevent water from entering and travelling through the cable). I'm not sure what type of cable was used for 'D'-side cables before plastic insulation was available. This would be the era before dropwires, when the drops were pairs of open wires. Perhaps someone could advise? Certainly, 'D'-side cables weren't pressurised.
