Author Topic: Measuring battery voltage in IOT  (Read 724 times)
Offline dobsonr741Topic starter
« on: November 01, 2023, 02:28:43 pm »
I’m making a RPi Pico board based IOT device, that wakes up by a TPL5110 in every few minutes, makes some measurements and evaluates whether to transmit the results over radio or not. Another reason to transmit in those wakeups when the battery is approaching empty.
The buck converter of the Pico is to be shut down/enabled by TPL5110 over the 3.3V_EN pin. How would you connect the always on battery voltage to the Pico’s ADC for measurements, with minimum part count and with no extra power consumption? Also not to stress the Pico with voltage applied to ADC in when it’s Vcc is zero.
Offline tszaboo
Re: Measuring battery voltage in IOT
« Reply #1 on: November 01, 2023, 02:34:28 pm »
Is this a one-off project, or a series production product?
« Reply #2 on: November 01, 2023, 02:43:46 pm »
A one-off project. I expect it to the run off of a single 18650 cell for more than a year.
Online langwadt
« Reply #3 on: November 01, 2023, 02:47:19 pm »
it already has that on Vsys
https://datasheets.raspberrypi.com/pico/pico-datasheet.pdf
« Reply #4 on: November 01, 2023, 03:10:29 pm »
Good point. What I don't like about it that it takes 14uA.
Offline Ian.M
« Reply #5 on: November 01, 2023, 03:31:33 pm »
Use an ultralow quiescent current OPAMP as a buffer for the potential divider and increase the divider resistors by an order of magnitude and you should be able to get that down to under 2uA, maybe even under 1uA.  The fly in the ointment is its then far more sensitive to surface leakage - you may need to slot the PCB under the resistors and even put a guard ring driven by the OPAMP output round its input node.
The other approach is to disconnect the top end of the divider when not sampling, and sample infrequently enough that the divider current is negligible.  Typically this is done with a small signal P-MOSFET, which requires level shifted drive, most conveniently provided by a N-MOSFET, using a complimentary dual pair to get them in the same package.  Add two resistors for P gate pullup and N gate pulldown, and your BOM is only four resistors + one dual MOSFET (+ an extra I/O pin).
« Last Edit: November 01, 2023, 03:39:20 pm by Ian.M »
Offline Andreas
« Reply #6 on: November 01, 2023, 03:33:37 pm »
Hmm,
why not switch the FET into the voltage divider?
If you use a port pin to control the gate you can even save energy after having measured the analog value.
Examlple see: T2, R23, R24 with GP4 as analog input.
With best regards
Andreas
« Last Edit: November 01, 2023, 03:36:06 pm by Andreas »
« Reply #7 on: November 01, 2023, 04:46:31 pm »
Great example! I’m planning to remove the offending parts on the Pico, and rebuild    it on the host PCB as your example. I might even get away with 2 AA powering instead of 18650
Online langwadt
« Reply #8 on: November 01, 2023, 06:14:21 pm »
move R6 and C3 to the other side of Q1 ?
The following users thanked this post: dobsonr741
« Reply #9 on: November 01, 2023, 06:51:50 pm »
Yup, that would work! Thanks!
