Author Topic: uA723 voltage regulator viable in 21st century?  (Read 52423 times)
Offline Richard CrowleyTopic starter
  • KJ7YLK
« on: June 29, 2018, 04:43:44 pm »
I can see why LM555 continues to be used, but why would antiques like uA723 and uA709 continue to be used in new designs?
Over in the GeekSlutz forum I was helping a guy from Sweden fix his audio mixer apparently designed in the mid 2000s.
The power supply is dead because the custom transformer (made by respected audio transformer maker Lundhal) has an open primary winding.
But the regulator design just seems completely antique.  It was obsolete when the thing was designed.  If you need + and - 15V @ 200mA, then why wouldn't you just use a positive and negative 3-terminal regulator (LM7815 and LM7915 or a modern descendent).
Service Manual PDF: https://data2.manualslib.com/pdf5/101/10098/1009764-satt_electronics/sam_82.pdf?373d3cacdef1450e71f59cd434f92921
Offline Conrad Hoffman
    • The Messy Basement
Re: uA723 voltage regulator viable in 21st century?
« Reply #1 on: June 29, 2018, 05:03:14 pm »
If you need it, you can customize fold-back limiting with the 723. It's still a good part!
Offline pelule
  • What is business? It’s other people’s money
« Reply #2 on: June 29, 2018, 05:38:26 pm »
Obsolete?
At least at TI the uA/LM723 is still active:
http://www.ti.com/sitesearch/docs/universalsearch.tsp?searchTerm=LM723#linkId=1&src=top
http://www.ti.com/sitesearch/docs/universalsearch.tsp?searchTerm=uA723#linkId=1&src=top
Call me old fashioned, but I am still use the uA/LM723 in my designs, if I need a bit more sophisticates linear regulation (i.e current protection or precisely adjustable voltage. I also still use the 723 as a very cheap temp-stabelized reference voltage (an old Elektor circuit to temp-regulate the on-chip reference using the on-chip pwr transitor as heater and the on-chip current sense transistor as temp-sensore).
/PeLuLe
You will learn something new every single day
Offline Bassman59
  • Yes, I do this for a living
« Reply #3 on: June 29, 2018, 05:48:48 pm »
Read more of the service manual! It uses a 709 in the input stage and the quad 4741 elsewhere. An RC4558 is used in the oscillator.
And zoom in on the schematic. It's dated 1976. So, no it's not modern, and it certainly wasn't designed in the 2000s.
(This kinda silliness is why I don't bother with GearSlutz ... it's all idiots talking in a circle jerk about audio gear they don't understand and have never used.)
Online schmitt trigger
  • Country: mx
« Reply #4 on: June 29, 2018, 05:53:08 pm »
My very first project employing an IC that actually worked, was a variable regulated power supply using a uA723. Which I used for my personal experiments for about 10 years.
So, I feel a lot of nostalgia for the uA723, and know that it is a very flexible building block which allows certain configurations like foldback current limiting.
But I would not use it today, for a couple of reasons:
The series pass transistor is not thermally protected.
I prefer spending my limited time, board real state and components in something more meaningful than a power supply.
  • KJ7YLK
« Reply #5 on: June 29, 2018, 05:54:49 pm »
Why do you say 2000s?  It looks like the schematics are dated 1976.
Doh! You are right.   :palm:
From that perspective, it seems more reasonable to see uA723.
I don't know where I got the notion that it was from the mid-2000s
Offline chris_leyson
  • Country: wales
« Reply #6 on: June 29, 2018, 06:00:54 pm »
As far as I know they're still available. Built a super low noise low power regulator a long long time ago, it performed much better that the low noise linear regs from TI, National etc. Can't remember the circuit but I think there was a big tantalum capacitor on the reference pin. They're very versatile regulator chips and like Conrad mentioned they're great for foldback current limiters. Even seen them used as switching regulators in the HP9825 power supply.
« Reply #7 on: June 29, 2018, 06:02:32 pm »
Indeed. It’s a power supply construction kit not a voltage regulator. And each chunk of it has pretty good performance.
Offline rdl
« Reply #8 on: June 29, 2018, 06:04:09 pm »
Quote from: Hackaday
... it’s an incredibly useful part because it does not present you with a regulator as such, instead it’s a kit of all the parts required to make a regulator of almost any description.
https://hackaday.com/2016/12/02/get-to-know-voltage-regulators-with-a-723/
I bought a handful of them years ago, and one of these days I'm actually going to use one for something.
Offline DimitriP
« Reply #9 on: June 29, 2018, 06:12:02 pm »
Stellar noise performance (with very few- maybe 6 - expections) and you don't need  magnifying glasses to see it.
  • Country: mx
« Reply #10 on: June 29, 2018, 06:13:21 pm »
A SMPS using a 723!
Now I remember a fascinating Unitrode app note describing a hysteretic regulator utilizing a 723.
The following users thanked this post: chris_leyson, austfox
  • Country: wales
« Reply #11 on: June 29, 2018, 06:41:16 pm »
Still available in TO100-10 package but £8 or £9 each !
Offline richard.cs
  • Electronics engineer from Southampton, UK.
    • Random stuff I've built (mostly non-electronic and fairly dated).
« Reply #12 on: June 29, 2018, 06:51:02 pm »
I used one at work a few months ago. I needed low noise and there are very few options for that in the voltage range I required. It's versatile enough to have a lot of uses, if nothing else keep a few in the junk box for when you need to build a slightly unusual regulator.
Offline pelule
« Reply #13 on: June 29, 2018, 08:55:44 pm »
Conrad, a German (not the cheapest) electronic seller offers:
Texas Instruments UA723CDR, SOIC-14 for 1,12 EUR/pcs
Texas Instruments UA723CN, PDIP-14  for 0,89 EUR/pcs
Texas Instruments LM723H/NOPB, TO-100-10 for 11,70 EUR/pcs
So plenty options still active & available
/PeLuLe
Offline glarsson
« Reply #14 on: June 29, 2018, 09:15:40 pm »
The enclosure that other manufacturers might have designed in 2006?
Offline rsjsouza
  • Eternally curious
    • Vbe - vídeo blog eletrônico
« Reply #15 on: June 29, 2018, 09:27:06 pm »
I too agree the uA/LM723 is still a useful part.
Funny how TI's product page for the LM723 shows an unwarranted comparison with the LM317L-N in the front page. (perhaps trying to steer people towards the other part). :)
http://www.ti.com/product/LM723
Offline Synthtech
« Reply #16 on: June 29, 2018, 09:28:40 pm »
I run a vintage synthesiser repair workshop, the uA723 is used in a lot of instruments and it is a part that rarely if ever fails. They are a workhorse that runs reliably for decades and it does it’s job very well. Three terminal regulators are also incredibly reliable of course but the 723 has advantages over them.
Offline glarsson
« Reply #17 on: June 29, 2018, 09:53:21 pm »
A SMPS using a 723!
In the early eighties I used a 723 as a heater element and heater controller for a crystal oven. The output driver transistor was the heater, a PN junction of the "free" transistor (normally used for current limiting) was the temperature sensor. Glue the crystal to the top of the DIP and pack with some insulating material.
The following users thanked this post: SeanB, Synthtech
Online KE5FX
    • KE5FX.COM
« Reply #18 on: June 29, 2018, 10:13:47 pm »
Only very recently have linear regulators been introduced that rival the ua723's noise performance.  The ability to bypass the reference is a big deal in some applications, and for a long time it was either use a 723 or roll your own.
Offline dardosordi
  • Country: ar
« Reply #19 on: June 30, 2018, 03:26:35 am »
The following users thanked this post: albert22
Offline edpalmer42
« Reply #20 on: June 30, 2018, 04:24:09 am »
FYI, the elektor version of the self-heated reference was in the 1978 July/Aug. issue on page 7-89 which is page 94 of this pdf.
https://archive.org/download/ElektorMagazine/Elektor%5Bnonlinear.ir%5D%201978-07_08_text.pdf
The following users thanked this post: cellularmitosis, albert22
Offline texaspyro
« Reply #21 on: June 30, 2018, 05:47:33 am »
Yep, and that new fangled stuff  can cost 10x-100x what you can get 723's for...  I recently bought 100 of them for $5.00.
Offline BravoV
  • +++ ATH1
« Reply #22 on: June 30, 2018, 10:49:18 am »
Thanks for the link, also extracted that page and attached below.
About the uA723 used as TC voltage reference, any idea what is the realistic performance ?
The following users thanked this post: sorin, albert22
Offline Wolfgang
    • Electronic Projects for Fun
« Reply #23 on: June 30, 2018, 10:52:37 am »
I think they chose this old chip because it has much less noise than a LM317, LM78XX and many others, even much more modern chips.
For low level audio, measurement and other sensitive app like low phase noise oscillators this can be important.
I learned a lot from a german paper about regulator noise (just looking at the graphs tells you everything you need):
https://www.bartelsos.de/dk7jb.php/rauschen-von-spannungsreglern
Another aspect is a datasheet value for long time drift and tempco. The cheap 3-legged regulators can be off by 5%, have up to 10mV of noise, a bad PSRR at higher frequencies, and no long term drift specs, plus a bad tempco in comparison. I agree that a 723 is more effort, but it can make sense.
The question for me is not if a chip is old or new, but if it does the job I need. Electronic design should not be based on what is fashionable, but on specs.  :)
There must be a reason why TI, ST and others still sell this methusalem ...
For prototyping, the availability of a DIP or TO-99 is also a plus.
Regards
   Wolfgang
PS: If you want to see some 732 designs for all kings of projects:
https://electronicprojectsforfun.wordpress.com/power-supplies/
and something a bit off-center:
https://electronicprojectsforfun.wordpress.com/silly-circuits/silly-circuits-a-heated-lm723-reference/
Offline blackdog
  • Please stop pushing bullshit...
« Reply #24 on: June 30, 2018, 11:29:54 am »
And do not forget my uA723 Oven designs  :)
https://www.eevblog.com/forum/metrology/small-oven-controler-for-voltage-reference/
Kind regards,
Bram
Necessity is not an established fact, but an interpretation.
The following users thanked this post: Synthtech
