No, not another tube amp, it's a transistor amplifier.
It is build using some large transistor modules rated at 1000V / 150A, these went normally into variable frequency drives or power inverters. Not particular suitable for a linear power amplifier, but ... it works.
The project isn't finished yet, I've got a set of three working power amplifer "modules", each using one of these large BJT blocks, and some support circuitry.
Bandwidth isn't exactly audio (DC to 10kHz), output power is huge and sustained (not like your home audio amp that starts burning if you run it at nominal power for a prolonged time)
See the thing here:
http://wunderkis.de/pwramp3/
