Author Topic: Reverse engineering a simple motorized cat toy  (Read 534 times)
Offline gsgxTopic starter
« on: July 23, 2023, 09:09:32 pm »
I took apart this cat toy recently as my cats didn't really like it and I wanted to take a look inside:
https://smartykat.com/products/twirly-top-electronic-cat-toy/.
Inside was a very simple circuit board (images attached) which controlled a toy brushed DC motor. When the power button for the toy is pressed, the motor turns for a second or two, causing the toy to roll in one direction and then stop, then after a short pause the motor starts turning again (I forget if the direction always switches back and forth or if it's random each time). It automatically turns off after a few minutes.
I attempted to reverse engineer how it works with just a multimeter, see the attached schematic. The problem is that I don't see any markings on either the U1 or U2 chip. I took a look under a microscope and still couldn't make anything out. There's nothing I can do to determine what chips they are other than use a logic analyzer/oscilloscope and find a datasheet that seems to match what I'm seeing, right?
My guess would be U1 is some type of microcontroller controlling the motor timing, when it detects a signal on pin 2 it starts outputting on pins 5 and 6 and different intervals to control U2. I'm as sure about U2 though, it gets input on pins 2 and 3 and drives the motor with pins 5 and 8. I'm not sure if pin 4 is some enable/reset type pin, I've never seen pins like that connected with a 2.2 ohm resistor.
Does anyone know what this U2 chip could be? Is it some amplifier IC or a motor driver IC? Even if I can't find the exact chip, if I can find a chip in the same package that can do the same thing, that would help me better understand what's going on and potentially make some improvements to the board.
Online ajb
Re: Reverse engineering a simple motorized cat toy
« Reply #1 on: July 24, 2023, 02:02:47 am »
U2 looks like an H-bridge.  Guessing that R1 is used when braking the motor, suggesting it would move in the same direction each time.  Or it just spins a little slower in one direction.  U1 is absolutely a microcontroller.  People still say "why use a microcontroller when you could use a 555...", but this is why: all of the timing and operational logic and h-bridge control logic in one chip.
« Reply #2 on: July 24, 2023, 02:12:06 am »
Thanks! I had literally just came across the DRV8871, which I think seems to match U2: https://www.ti.com/lit/ds/symlink/drv8871.pdf
« Reply #3 on: July 24, 2023, 02:21:45 am »
Oops, it's not exactly a drop in replacement. Pin 1 is GND for the DRV8871, not VCC. But it's pretty close, so I get the idea of what's going on.
