There are also data switches that can act like a multiplexers.
Might I suggest that when working with logic very few problems remain.
You should look for a chip or chips that solves the problem.
As others have said it would have been much quicker if you had said,
" I Need to connect the outputs of these chips based on time"
With chip numbers you would have gotten a good answer much quicker.
