I was wondering if anyone knows if the Linear Technologies LT3081 voltage regulator can be used with a limit resistor ( Ilim ), below 450 ohms to limit output currents to below 135mA. This would be in the voltage range from 2-8 Vdc for various LEDs, including the UV-C that operates on 6.5-8 Vdc at 60-80mA. The data sheet gives no minimum value for Ilim, and just says that a typical value is no less than 450 ohms. What would happen with lower values of current limiting resistors? The Rlim equation is also written in a confusing manner.
