increase C1 till the MCU starts successfully, then increase it another 50% to have a safety margin.
It's a nice circuit. It's simple yet effective and the short burst on is a nice touch. I can't foresee it ever causing a problem for the Pico since the voltage applied to EN is actually under 3 volts (like 2.6-ish). So much nicer than using the SS Relay.
OK, now I have questions:
1) Am I correct in assuming that once the cap charges, the full 12 volts will be applied to that 50k resistor feeding the base of the transistor?
2) The 1N4001 seems to be working (though I'm not sure what to expect if they weren't working). Do you foresee a problem sticking with this diode?
3) How did you find the datasheet for the buck converter based on only having the data from the Amazon page?
4) How did you know that the resistor on pins 2 and 6 was the one causing EN to default high?
Edit: I just confirmed that when in the off state, it only draws .3µA from the 12 Volt source feeding the buck. Life is good
![Grin ;D](https://www.eevblog.com/forum/Smileys/default/grin.gif)
