Ok here is as far that I would go for now .
I managed to pull out the analog organ from the body .
I had select nine pictures full resolution ( no editing ..)
Inside there is dual PCB , the bottom PCB handles the relay,
plus it is used for all the big parts ,
I could describe it as an high amperes highway , that connects to the banana plugs.
The top PCB has the software (
![Grin ;D](https://www.eevblog.com/forum/Smileys/default/grin.gif)
) , small transistors and diodes. ( ohms range + voltage)
Both PCB looks to me in top shape ,
what looks amazing as detail , are that even the curves of the leads, in the resistors,
they all have the same shape, they must had make an special tool, just for that.
I noticed inside few particles of dust , no oxidation or damage in anything .
I found some pressure points at the top cover, that probably releases the top cover , but I will not try to open them.
Because there is also similar release points at the bottom,
that looks that you have to use an specific tool for those ,
shaped as large fork , and probably only the factory has or had, one of those.
This shaped as fork - key ... must look similar with the special ones for the car stereos ( and usually comes with them) ( easy installation and removal)
The analog organ ( meter) has an transparent window at the bottom of it.
Just an production code , and no other info.
There is three copper plates at the left , I think that is the amperes shunt , I could be wrong too.
For an complete tear down you need to know all the steps , like one - two - three ,
looks as very complex design even to me .
That I have an good experience from hundreds but
modern, devices.
And finally looks more modern than those AVO
