The multiple-emitter input transistors are why this type of circuit is called "TTL" (transistor-transistor logic), as opposed to "DTL" (diode-transistor logic).
Many BJT logic ICs are called TTL, when they are actually DTL with Schottky diodes.
A generic name for this style of IC is "current-sinking logic", where the current to be sunk is either diode current or emitter current, and the sink is a grounded-emitter NPN output (usually with active pull-up circuit).
The important feature of current-sinking logic is that the input-low input current is much higher than the input-high input current, as opposed to CMOS which is more balanced.
