Always check the
article errata."Full Wave 10A Motor Speed Controller, March 2018:
(1) The mains Active wiring to the fuse holder shown in Fig.2 should show the incoming mains wire (brown) connecting to the tip of the fuse holder rather than the side ring terminal. The wire through the current transformer should then connect to the side ring terminal of the fuse holder. Also, the paragraph before the “Current Feedback” cross-heading on page 39 refers to pin 2 connecting to the 4.7nF capacitor. It should say pin 5. These errors have been fixed in the online edition. (04/18)
(2) In the circuit diagram (Fig.1) on page 36, the “Active In” wire from FUSE1 is shown connecting to the top-most terminal of CON1 and it then goes through the core of transformer T1. This is incorrect; the wire from FUSE1 goes directly to T1, then to CON1 and on to the A1 terminal of TRIAC1. The overlay and wiring diagram (Fig.2) on page 40 is correct. (02/19)
(3) A bug in the original software (1010218A) prevents the feedback speed control from working after the soft-start period. Revised software (1010218B) is available online. In the circuit diagram (Fig.1), the electrolytic capacitor connected to the junction of the 10kW and 1kW resistors to the left of diode D5 should be 10μF, not 100μF. Some PCBs sold may also show this capacitor as 100μF but the overlay diagram, Fig.2, shows the correct value of 10μF. VR2 is also shown as 1kW in the circuit, but should be 10kW as in the parts list and overlay. (12/19)"
