Author Topic: Powerful (and hackable!) Flashlight Kit  (Read 1010 times)
Offline T3sl4co1lTopic starter
    • Seven Transistor Labs
« on: December 06, 2017, 12:15:28 am »
This is the design I've shown and discussed elsewhere, now realized in non copper-clad-prototype form as well. :)
Powerful enough to suck down an 18650.  Not sure if these cells are in need of a charge, or just old and weak, but I'm only getting 50% of rated power out of these.  Nothing wrong with that, of course -- the undervoltage limiter circuit prevents brown-out failure.  That's why I know I'm getting only 50%. :)
Very hackable design.  Lots of test points.  Two resistors change it to a portable, adjustable bench supply!
Seven Transistor Labs, LLC
Offline CJay
Re: Powerful (and hackable!) Flashlight Kit
« Reply #1 on: December 06, 2017, 06:55:59 am »
At that implied power level I bet it makes a nice hand warmer too :)
« Reply #2 on: December 06, 2017, 09:15:28 am »
Th old 1W flashlight I made, you can feel it, particularly in a sensitive area like point blank on your lips.
You can feel these in your hand, unmistakably. ;D
