I should put the investigation of the "2222, 3904, 4401, and BC847" on my list. Unfortunately the list is long...
![Grin ;D](https://www.eevblog.com/forum/Smileys/default/grin.gif)
![](https://www.richis-lab.de/images/transistoren/b49x01.jpg)
Here we have another one of this era. BTW: I have flipped the numbers. The package of the 2N3568 and the 2N5136 is called TO-105, not TO-150. The smaller version is called TO-106.
The American semiconductor manufacturer Continental Device Corporation (CDC) emerged from the semiconductor division of Hughes Aircraft and was later acquired by Teledyne. CDC co-founded the Indian semiconductor manufacturer CDIL.
There is no separate datasheet for the CDC 2N5136. The 2N5136 variant from Fairchild is specified with a reverse voltage of 20V. At 150mA, the typical amplification factor is 100 and the datasheet specifies a factor of 2 as the minimum for high-frequency amplification at 20MHz. A power loss of up to 300mW can be dissipated via the TO-105 housing.
![](https://www.richis-lab.de/images/transistoren/b49x02.jpg)
The epoxy encapsulation does not contain any fillers, which is why only a small amount of material remains after thermal conversion. The collector pin is bent and widened in the housing. The actual transistor is located on it. Base and emitter potentials are supplied via bondwires. The transistor is protected with additional potting.
![](https://www.richis-lab.de/images/transistoren/b49x03.jpg)
Although the additional potting has not burnt, it has become brittle. The impression shows that the transistor is almost too large for the metal surface.
![](https://www.richis-lab.de/images/transistoren/b49x04.jpg)
![](https://www.richis-lab.de/images/transistoren/b49x05.jpg)
Some of the potting still adheres to the die.
![](https://www.richis-lab.de/images/transistoren/b49x07.jpg)
![](https://www.richis-lab.de/images/transistoren/b49x06.jpg)
The edge length of the die is 0,88 mm. Contacting the base potential is possible on two sides. The star shape of the emitter ensures a low base resistance with a slightly larger emitter surface. Smaller transistors do not require any special geometries. Power transistors, on the other hand, usually have finger-shaped interlocking structures.
https://www.richis-lab.de/BipolarA61.htm ![Tweak :-/O](https://www.eevblog.com/forum/Smileys/default/smiliey_cal.gif)
