Author Topic: Transistors - die pictures  (Read 257106 times)
0 Members and 11 Guests are viewing this topic.
Offline Wolfgang
    • Electronic Projects for Fun
« Reply #175 on: August 12, 2020, 09:02:23 pm »
Hm... Somehow I managed to kill the 2N2857...
Unfortunatelly I can´t say what went wrong. I was in a hurry. That´s never a good thing.   :-BROKE :-//
I guess the poor thing needed some limiting for current and power and did not get any :)
Seriously, these parts are not forgiving at all. When you look how they are mounted (on a pin header)
you can imagine that Rth is very large and heat capacitance is very small, i.e. they blow up in milliseconds.
Remedy: use a SMU and set the limits small enough. Fortunaterly, they are cheap.
Offline NoopyTopic starter
    • Richis-Lab
« Reply #176 on: August 12, 2020, 09:21:58 pm »
That´s not "medium" it´s more "well done".  ;D
@Wolfgang: SMU and cheap are two words that don´t match.  ;)
I still haven´t set up my HP-supply...  :-\
Offline David Hess
  • DavidH
« Reply #177 on: August 12, 2020, 09:52:49 pm »
Somewhere I have seen a table with bond wire fuse ratings for use in failure analysis.
« Last Edit: August 12, 2020, 11:41:27 pm by David Hess »
Offline Wolfgang
« Reply #178 on: August 12, 2020, 11:30:11 pm »
Sorry I meant that the transistors are cheap. An SMU is not, and I know that after Keysight got all my money :)
Something affordable you could make is a current limiter circuit (I think there was a Jim Williams app note about an electronic fuse).
Thats not rocket science and will prevent a few kills.
    • Richis-Lab
« Reply #179 on: August 13, 2020, 04:16:42 am »
Up to now I use a cheap bench supply but it has a current limiter of course.
I should have worked more concentrated. The fault is mine....
Offline Wolfgang
« Reply #180 on: August 13, 2020, 09:50:08 am »
Using a normal PSU with sensitive semiconductors is a problem even with a current limiter.
The problem is the energy stored in the output cap and the slow response of the limiter.
What you need is a limiter/electronic fuse that is fast and has no big electrolytic at the output side.
    • Richis-Lab
« Reply #181 on: August 13, 2020, 10:15:52 am »
Yeah, I agree with that. A SMU would definitely be a nice piece of equipment. :)
Online RoGeorge
« Reply #182 on: August 13, 2020, 12:39:07 pm »
I proudly did once a demonstration about my latest tool purchase, a brand new Rigol DP832 power source, and how great it is, and how it can serve as a voltage source, or as a current source, upon wish.
And to prove my point, I set the current to 20mA and confidently hooked up a LED to the wires.   :-+
The LED flashed then instantly died with a violent pop sound, I jumped back, and my friend burst into laughter.  :-DD
Those 20mA were enough to charge a few thousands uF of output capacitors up to 32V, then all the energy rushed into the LED, limited only by the ESR and the wires.  In DP832, the output filtering capacitors are located at the end side, in direct contact with the output terminals.  ;D
Regarding the melted bonding wires, they are terminated in intriguingly round spheres of metal, and also there is a segment attached to each sphere, segment that looks like it was melted too but only at its surface, and somehow kept its initial cylindrical shape and its initial diameter, then the rest of the wire suddenly looks like brand new.
How is that possible?  :o
« Last Edit: August 13, 2020, 12:47:24 pm by RoGeorge »
Offline SilverSolder
« Reply #183 on: August 13, 2020, 01:26:20 pm »
That's what happens when you use an instrument that is too new and inexperienced!  :D
Offline Mecanix
  • Country: cc
« Reply #184 on: August 13, 2020, 03:23:29 pm »
Interesting. Mine (DP832) ramps up beautifully, no inrush or spikes whatsoever on all 3CH, smooth as silk and stable. Recently had it calibrated also so add in that now impressive accuracy, its incredible now.
Offline Wolfgang
« Reply #185 on: August 13, 2020, 03:51:40 pm »
I have a lot of DP832s, and they perform fine. Three things to take care:
- The startup spike only occurs when the load is *very* light.
- Its not an SMU, so accuracy is what is in the datasheet. Last digit has to taken with a larger grain of salt, as usual
- They do have an output cap, and the energy in this cap gets dumped into your load with no current limit being able to do anything against that.
So, if you set voltage to 30V, current to 10mA and then connect your LED, it could still be dead because of the cap discharge current.
Online RoGeorge
« Reply #186 on: August 13, 2020, 06:47:39 pm »
I apologize about telling the offtopic tale with the DP832.  I didn't want to hijack the topic.  Should have kept my mouth shut.  It was not the power source's fault, it was my mistake.  Just let it be.  Please let's get back on topic.
Anybody knows more about the 2 spheres formed at the end of the melted bonded wires from the last transistor's pics?  Are they usually so round and alike looking?
Offline capt bullshot
« Reply #187 on: August 13, 2020, 09:44:06 pm »
If you don't have an SMU, a bunch simple resistors should do the job.
Use the lab supply in voltage mode, roughly calculate the required resistance and put the resistor in series to the DUT. Measure the actural current with your multimeter and adjust the output voltage to set the desired current.
Disadvantage: for covering a larger range of currents, one has to switch resistors.
Your typical old-style curve tracer (e.g. Tek 576) does it this way. Pretty simple and effective. The modern ones have multiple digitally controlled SMUs to achieve the same results.
    • Richis-Lab
« Reply #188 on: August 13, 2020, 09:51:20 pm »
Well the surface tension of the liquid metal forms a ball...
Usually my bench supply is good enough for most applications.
I just have to keep calm while meassuring.
I was in a hurry that´s never good...  :--
    • Richis-Lab
« Reply #189 on: August 19, 2020, 06:53:19 pm »
Today I have a MJL21193 for you (250V/16A/30A):
The die is quite big: 3,64mm x 3,54mm
I was wrong with the die size!  :o
In fact the die is 5,48mm x 5,36mm! That´s quite big, 5,5 times the ST TIP3055!  8)
 :popcorn:
    • Richis-Lab
« Reply #190 on: August 19, 2020, 07:46:45 pm »
Today I have a new 2N3055 for you, a Motorola 2N3055:
http://www.richis-lab.de/2N3055_07.htm
The characteristic old package with the characteristic low, more round cap.
I don´t think that round low thing is a heatspreader. Perhaps they needed this small plate to manufacture the transistor.  :-//
The design is "quite modern" and uses a mesa structure.
 8)
11V 10mA
20mA
30mA
40mA
50mA
100mA
200mA
300mA
 ;D
Offline ocw
« Reply #191 on: August 21, 2020, 10:52:48 pm »
After prior pictures of a good SD2942W with more zoom https://www.eevblog.com/forum/projects/transistors-die-pictures/msg3138636/#msg3138636 , attached is a picture of the same SD2942W with less zoom along with one damaged by lightning.
[ Specified attachment is not available ]
« Last Edit: August 22, 2020, 05:03:46 am by ocw »
The following users thanked this post: exe
Offline Jay_Diddy_B
« Reply #192 on: August 22, 2020, 02:53:28 am »
You need to find a big transistor like this one:
I have included a TO-3 transistor in the picture for scale.
The BJT is rated at 200A 700V.
I am not ready to open this one up. The silicon will probably be 33 or 38mm in diameter.
Regards,
Jay_Diddy_B
    • Richis-Lab
« Reply #193 on: August 22, 2020, 06:35:06 am »
Well that's really a big one! :D
    • Richis-Lab
« Reply #194 on: September 05, 2020, 09:09:57 pm »
Today I have a really old 2N3055:
Here you can see the protective coating of the die and the higher emitter since it is a hometaxial transistor.
Of course  I did some breakdown pictures. The fabrication process didn´t create very smooth structures. You can see that the breakdown light is quite non uniform even at high currents:
0,1A
0,2A
0,3A
0,4A
0,5A
0,6A
0,7A
0,8A
And there is a small structural flaw:
https://www.richis-lab.de/2N3055_08.htm
The following users thanked this post: RoGeorge, Sredni
« Reply #195 on: September 06, 2020, 01:04:13 am »
Interesting with that old 2N3055, it seems technology has moved on and we are making much "cleaner" devices nowadays?
    • Richis-Lab
« Reply #196 on: September 06, 2020, 07:03:34 am »
That is for sure.  :-+
    • Richis-Lab
« Reply #197 on: September 06, 2020, 08:42:09 pm »
Finally we can compare the hometaxial RCA 2N3055 with the epitaxial RCA 2N3055:
The metal layer has an interesting structure. It seems that RCA had to modify the layer to do some current steering. You can see that while driving the base-emitter-junction in breakdown:
There are two very bright areas. There is no small bright point as we have seen with impurities. It´s more a line getting constantly brighter and dimmer. For sure that is a local higher current density.
In the bottom left corner of the base contact RCA has integrated two holes in the emitter area to increase the resistance and reduce the current density.
In the bottom right corner of the die RCA added even a small electrode connected to the base potential over the silicon.
https://www.richis-lab.de/2N3055_09.htm
 :-/O
Offline David Hess
  • DavidH
« Reply #198 on: September 07, 2020, 04:28:50 am »
Early processing was incredibly crude by modern standards.  Today you could do better in your garage.
Online magic
« Reply #199 on: September 07, 2020, 09:04:41 am »
