I think i'm doing ok. I used your advice and grounded the bottom of the schematic and everything looks alot better now. I'm using the Bode plotter and I get images similar to the one in the picture but the scales are different so they don't look exact but you can see that they start, stop, dip and everything else at the same places.
Thanks for your advice. It worked a lot better this time with your help and a little sleep.
My problem now is getting the scales and ticks right to match the drawing. Its not completely necessary I just like way the Tone stack calculator looks.
anyway, Thanks again.
