I and Simon Law are proud to have recently finished the thermNeon by SALTechips, making it available as fully assembled or as a kit.
![ThumbsUp :-+](https://www.eevblog.com/forum/Smileys/default/icon_smile_thumbsup.gif)
It is, a contemporary room thermometer based on a nixie bargraph tube!
We are excited like kids at Christmas and made a kit available as a free give-away
here. Just leave a comment and you are in!
We grew up tinkering with electronics and reading magazines like Elektor and Silicon Chip. So in the rest of the post I will share a bit of what we were thinking when working on this project and some of the challenges we were faced with. We have 100s of pictures from the bench and the whiteboard; a few are included here!
The schematic and firmware of the themNeon are freely available under CC and GPL. You can download them from our website
here. Adding a remote temperature sensor would be pretty cool but elegantly switching between the two...
![Confused :-//](https://www.eevblog.com/forum/Smileys/default/confused0024.gif)
Back in 2009 I was experimenting with obsolete neon display technology, ‘nixie’ tubes. One such tube reminded me of old alcohol thermometers, so I decided to build an analogue thermometer around it. This was my prototype:
![](http://img713.imageshack.us/img713/6277/prototypealex.jpg)
Feeling that my idea was novel, I performed an Internet search only to discover that Simon had assembled the same concept independently. Recognising the weaknesses of the analogue version, I contacted Simon coining the idea of working together on a digital version. This is Simon's prototype (mine is better because you can see the wires
![Cheesy :D](https://www.eevblog.com/forum/Smileys/default/cheesy.gif)
). Note 'The Art of Electronics' in the background!
![](http://img690.imageshack.us/img690/2543/prototypesimon.jpg)
Driven by our desire to share our passion for electronics, and not being impeded by the physical distance in excess of 17.000 km, we agreed to collaborate and SALTechips was born.
The project concept revolves around the IN-13 nixie bargraph tube used as the temperature indicator. We wanted to simulate old mercury/alcohol thermometers with a modern twist. This is the tube I am talking about:
![](http://img545.imageshack.us/img545/7818/in13nixietube.jpg)
This tube is based on a retro technology that just won’t go away! Before LED and LCD displays, neon indicators were used to display numbers or quantities in all sorts of electronic equipment, from multimeters to truck scales. These tubes (produced in several countries) were slowly phased-out about the same time as the collapse of the Soviet Union. Our stock of IN-13s is date-coded April ’92, one of the last production runs. They are bulky, fragile, expensive and power hungry. But the neon glow has an addictive karma to it, a mesmerising glow hard to describe with words; you just have to see it. Recently this technology is enjoying a revival in clocks, VU meters and thermometers to name a few. You will also find it in power strip indicators and on Wozniak’s hand.
Scale design:Project design began with the scale. We wanted to protect the glass tube from knocks but not obstruct the view. A thick acrylic piece was LASER cut and a channel machined along its length. The tube slides in the channel and, since it is thinner than the acrylic scale, it is well protected. The numbers and gradations were LASER etched on the acrylic with deep etching to capture more of the light travelling inside the scale. Special care was taken to prevent the sensitive electrodes of the tube from cracking if the scale was stressed. Here are the first prototypes. Clearly the engraving on the first one on the left failed
![Face Palm :palm:](https://www.eevblog.com/forum/Smileys/default/facepalm.gif)
Base designWe also designed the base. Choice of materials and mounting methods was entirely up to us, hence a lot of effort went into finding optimum solutions. We tried several shapes and sizes of bases, even the ‘golden-ratio’ from ancient Greece...
![Roll Eyes ::)](https://www.eevblog.com/forum/Smileys/default/rolleyes.gif)
At the end we used the one that was just right (see Modelling) and suited the scale dimensions. We decided to use individual pieces of wood to capture the warm glow of the neon tube. As the thermNeon is also available as a kit, we did not want to use glue in the assembly of the base. Finger joints were designed in the base panels that are also LASER cut. To secure everything together a combination of fasteners was selected after many hours of trial and error with standard-length mechanical components. A stain and finish was used to highlight the grain and seal the pores of the wood to provide resistance from the elements and scratches.
Here we were trying to figure out a mechanical fastening solution using standard parts:
ModellingWhile designing the scale and base we had many different ideas; ‘how would that look, how about this’? It is not economical to make prototypes of all the ideas so we decided to create a full model of the thermNeon (tube, scale, base and PCB). This proved valuable as we could not only check how different wood finishes would look, but also check for clearance problems with the connectors at the back.
This is a render of the scale before the LASERs were fired up:
![](http://img707.imageshack.us/img707/4417/scaleassembly2.jpg)
The base in cherry:
![](http://img690.imageshack.us/img690/2926/cherryg.jpg)
and inside the base for the mounting hardware:
Electronics!When it came to designing the electronics of the thermNeon we already had a very good idea of what would be involved. We started by interconnecting functional block diagrams of the different subcircuits. The schematic diagrams were then produced in EAGLE and simulated in PSpice, LTSpice and Mindi. Here is our prototype, built to check the results from the simulators. Isn't the aim with simulators to prove that they work?
![Laughing :-DD](https://www.eevblog.com/forum/Smileys/default/smiley_laughing.gif)
![](http://img443.imageshack.us/img443/2728/thermneonprototype.jpg)
Some of the firmware functionality such as the switch-mode controller was implemented in hardware until the firmware was ready; the stuff hanging off board. We decided to use mostly THT components to make assembly more accessible. We are still not sure if most hobbyists are comfortable with full-SMT board?
And here is a fusion of the designed PCB, 3D render a physical populated board. This is Simon's idea. We are very proud of this and will claim all credits and karma points.
FirmwareThe firmware was written in C in MPLAB X using the C18 compiler. We put everything in 1 C file to make compiling easier. About ¼ of the time went into documenting the C statements to improve readability and serviceability. A PIC MCU was selected as we both had a toolsuite running. The PIC18F1330 contains 3 hardware PWM channels, making it easier to control the number of PWM channels in the thermNeon (6 in total). The remainder of the PWM channels were implemented in software and assigned to lower-priority functionality. The most challenging part of the firmware was the colour mixing for the scale illumination. Two RGB LEDs are assigned a 4-bit intensity value per die for a total of 4096 colours. The RGB values are calculated by a function that accepts an HSV colour representation, calculated depending on the read temperature, hot/cold user temperature setpoints and hot/cold user colour settings. Consequently these two functions have the largest Flash memory footprint. The EEPROM library used to store and recall user settings was copied and modified from a computer server water-cooling project.
Here is the call graph from the 'main' function. I really like seeing this functionality in MPLAB X.
![](http://img22.imageshack.us/img22/3798/callgraphmain.jpg)
These tubes have huge variations so calibration was tricky. Here is the first out of five pages on calibration, handwritten on some train...
TestingTesting is not to verify that everything works, but to find what doesn’t and correct it. Besides all the standard electrical tests on the thermNeon itself, we tested the power supply bricks from our suppliers as we had not worked with them in the past and wanted to build trust. Due to the large number of units to test, a script was written for a Maynuo M9712B electronic load. We also put the themNeon in an environmental chamber to test its accuracy over the displayed temperature range and also its durability over the commercial product temperature range.
Here is the matrix board prototype on the bench. Here I was testing the gated oscillator power supply controller:
ManualsWe strongly believe that a project or product has failed if one needs to refer to the manual to get the core functionality to work. Let’s face it, user manuals are rarely read before plugging the product in. But every now and then you need to setup for some unusual measurement or change a rarely used setting and for that a manual is useful. We wrote a User manual and also included a summary of the settings under the unit’s base for quick reference. A lot of effort went into the Assembly manual for the kit and covering tricky assembly stages. Don’t leave it to the designers to decide what is covered - they know too much. Give a kit to a friend and take notes while they are building it!
![Tweak :-/O](https://www.eevblog.com/forum/Smileys/default/smiliey_cal.gif)
Getting it out thereBy now we had an expensive prototype that no one knew about. In order to share our project with the world we had to negotiate favourable component costs with multiple suppliers across several countries and continents. We vividly remember rejecting ludicrous offers from a couple of suppliers. Always do your homework before asking for a quote.
The final challenge was to share our excitement about our project with the rest of the world, some call it marketing.
![Lips Sealed :-X](https://www.eevblog.com/forum/Smileys/default/lipsrsealed.gif)
We identified our audiences, designed a website and online store, photographed the completed project, made a promotional video, had the project reviewed, approached retail shops...the list is long and ongoing.
![](http://img811.imageshack.us/img811/7525/dsc0063un.jpg)
![](http://img94.imageshack.us/img94/3373/thermneonkit.jpg)
To conclude, it has been a long journey from the original idea to the finished project. The electronics is only part of what one needs to consider and put in place before making the project available to others. But seeing someone that you have never met praising the outcome of your work and taking one for home cannot easily be described and is very motivating for the projects to come! From our experience we would encourage other members of this forum to collaborate on projects. Start from a project of common interest like we did; share material and ideas on dropbox. You never know what lies ahead!
We can't hyperlink you to our labs where we spend most time, but you can find us on
SALTechips.com,
YouTubeand when time permits also on the EEVblog
![Wink ;)](https://www.eevblog.com/forum/Smileys/default/wink.gif)
Oh, we have no shame to be on
Facebook too.
Alex.
