Very cool (hot?)
It's not my intention to slam your project, but offer the following as FYI ...
A lot of parameters that can be safely ignored when reflowing chip caps, resistors, and SOICs should be taken into account when trying to reflow BGAs and QFN/QFPs. Most importantly is the temperature profile. In a commercial reflow oven the temperature follows an exact and specific profile. In general terms, something like ....
PRE-HEAT ZONE - The board is SLOWLY brought up to an idle temperature, just below the activation temperature of the flux. Most component guys recommend no more than 2 degrees C per second. The board will be brought up to about 170C in this zone.
SOAK ZONE (flux activation) - The board is then heated to the point at which the dehydrated flux chemically activates and does it's thing, and time is allowed for the entire board and it's components to reach the same temperature. The board will go from about 170C to 220C in this zone.
REFLOW ZONE - The board temp is then peaked into the reflow range of the specific solder paste being used. It was typically held there for another 30 seconds to a minute. The temperature depends entirely on your solder paste chemistry.
OUT RAMP (cooling) - Finally the board is SLOWLY cooled down to a temperature of about 90C over the course of another 3-4 minutes.
The importance of the gradual preheat is to avoid thermal stresses and fractures in the PCB and within the components.
The importance of the soak is to avoid solder balls and voids.
The importance of the controlled cool down is that you want it slow enough to avoid thermal stress, and yet fast enough that the solder can form the optimal granular structure to ensure a solid mechanical connection.
Now, this CAN be accomplished with converted toaster ovens, but I've never seen it done. The oven conversion projects I've seen published that pretty much drive the temperature directly to reflow, and then kill the power, make me grimace.
There are lots of references on the web, but here's a pretty decent one...
http://www.rayprasad.com/home/rp1/page_70/smt_-_lead-free_reflow_profile_development_part_1.htmlGood luck, and keep us informed on how it all works out!
