Hello,
I am designing a PCB that will use a TO-71 package component, and am trying to decide on the correct footprint to use for the layout. With pins in a 100mil diameter circle, there isn't much room to use for the pads and plated through-holes. If I had more space, I would probably go with 25mil diameter holes in 40-50mil pads. Should I not be afraid to spread the pins on the TO-71 component and use a wider hole/pad spacing for the PCB? Does anyone know what the standard practice is in designing a PCB that uses TO-71 components? The internet hasn't been much help on this question, and datasheets also avoid the topic. (The specific component in question is an LSK389 dual N-channel JFET from Linear Systems.)
